OPTI Questions
Old Aug 26, 2005 | 01:44 PM
cmerc's Avatar
Default OPTI Questions
I need some guidance if possible, I have a '94 Z which has been highly modified 550 HP. The opti has been upgraded by the previous owner to a More Performance opti-spark Vented unit. However the vacuum harness was not used, I have been driving in rain for the last 2 days and now have idling issues which I suspect may be the opti I am looking for the following:
1 A schematic of the vacuum harness connections
2 I need to find out which port on the opti is the "in" line and which is the "out line" I read a post that blowing compressed air into the “in” port could help, is this true?
3 Also can the cover & rotor be changed with out removing the whole opti unit.
Sorry to be so full of questions but as I live in the Bahamas it is impossible to find these things out without diving head first into it, as I said the opti is the new style vented unit but the lines were never installed, is it possible that because of this moisture could have more easily have gotten inside.
Old Aug 27, 2005 | 05:57 PM
97LT1's Avatar
I will look for you tommorow when i adjust valves. I have heard the compressed air is like a shot in the dark. I would not leave those vent holes open however. I would try to hook up the lines and see what happens.
Old Aug 30, 2005 | 04:29 PM
jdawgs94z's Avatar
http://gmhightechperformance.com/tec...htp_optispark/
hope this helps
