Stock Exhaust
I have a 93 where tuning is not really an option unless I buy a new chip for every tune. I have long tubes, all emissions are gone, and have run a 12.2 @120 without a new chip. Maybe tuning for 94+ cars are more necessary than 93's. Must be an OBDIII thing.
All I know is that in 93 you needed to replace the chip, in 94+ you could reprogram the chip so it was alot easier to highly modify a 94+ car. If a 93 - 95 both had OBDI, then I would think that you could do the headers, converter, remove the AIR just like I did and not have any problems. You seem like you know more about tuning than I do though.
I just called up Automotive Engineering and they gave me a price on some hooker long tube headers. $450 for the headers and $170 for the Y-pipe. That's pretty ridiculous. I'm starting to think that it's not worth it. All that money for like 10hp? Anyone know where I can get some a little bit cheaper. People are telling me the pacesetters are cheap and won't give me the HP I can get. I've also heard that they have just ripped apart on some kid that lives local around me. I'm confused, any ideas? Maybe I should consider a different mod next? Although, headers seems like the most logical.
Currently I have a Moroso CAI, underdrive pulleys, 160' thermostat, exhaust without the cat and the metal intake elbow.
Thats pretty much the cheapest mod you are going to find that you still need. Longtubes and a new y pipe should gain you closer to 20 hp though. I still say go with the converter. .5 second gains
Also do the throttle body bypass
Also do the throttle body bypass The throttle body bypass gets me paranoid. I always think down the road I'm going to end up dripping coolant on my opti. I'm not the most mechanically inclined person and would not trust myself with that. I would constantly think something was going to happen. For a mod that may give me 2 hp, I think I should save my worries.
So, there is nothing else I can do? A stall is like a 1000, isn't it? I would consider getting a gear, but I already have 3:23. I think those are good for now.
(COPY)
(COPY)
(COPY)
(COPY)
I didn't put the feed line onto the steam pipe all the way and it DID leak coolant, but after it's on all the way, you are safe to go no doubt. Give it a shot. Just disconnect the MAP sensor, and the alternator brackets and you'll have SO much more room. Have some confidence in yourself man! Looking at all this and doing all this will give you a great deal of knowledge on your car. I say give it a shot, it's worth it!Here is a walkthrough on the TBB You should also get a tune from Ion at Madz28.com and throw in a 160* thermostat
I have a 160' thermostat. Also, that walkthrough is for 95-97 Z28's. The problem I am worried about is after I do the installation. Over a period of time, I don't want it to end up leaking. I have a few bolt ons, my next mod will be headers. I just have to find the right set.
It won't end up leaking, unless it's not put on the steam pipe all the way. You'll be fine. It's almost a no brainer when you're actually doing the installation.
