AIR and EGR block offs?
Old Aug 29, 2005 | 01:38 PM
blind527's Avatar
Default AIR and EGR block offs?
I want to disconnect my AIR and EGR stuff. I just need to take the AIR pump out along with the hoses, then block off the passage I left that goes into my headers correct? What do I block it off with? Is there a certain AIR block off plate that goes into the header? I have Jet Hot LT's. I need to use these hoses for something else, I have the EGR and AIR deleted from the PCM. With the EGR block off plates, I only need 2 right? And both of them are on the drivers side of the intake manifold? One of the EGR tubes connects from the drivers side of the intake manifold to the passenger side that has that little tube that goes into the headers right? I just need to know what I need to block the AIR off with. If I remove the AIR pump will I need block offs for that as well?
Old Aug 29, 2005 | 02:19 PM
simple's Avatar
make your own
when you pull the piece off the exhaust manifold, take the flat piece with the hole in it that the ribbed tube went thru off. make a small piece of aluminum or whatever about the same size as that with a hole in it for the bolt too be screwed back into the manifold. use some high temp RTV too help seal it
do the same for both openings on the back side of the intake
dont buy the block off plates when you can make them for free
when the air pump comes out, you will need too block off both openings at the maniflods and one on the intake tube
Old Aug 29, 2005 | 02:26 PM
FIREHAWK #07's Avatar
maybe this will help.....
http://www.sjmmanufacturing.com/cam_eng_lt1.html
http://web.camaross.com/forums/showt...ght=egr+plates
Old Aug 29, 2005 | 02:37 PM
blind527's Avatar
No I know how to take everything out, I just needed to know if there is a special AIR block off that I need. I know how to take most of it out, I found a thread after I posted this, but I just needed to know if I need to block off the AIR tubes when I remove it off the headers.
Old Aug 29, 2005 | 03:14 PM
monster7's Avatar
here is a pic of mine its just 1/8 alum plate that is cut and i use rtv to seal it
Old Aug 29, 2005 | 04:58 PM
blind527's Avatar
Does anyone know the size of the vacuum cap needed for the CAI? It's a LPE. I know I need a 5/8" vacuum cap for the line that went into the intake manifold. Does anyone know the size needed to fit an oil drain plug into the headers?
Old Aug 29, 2005 | 08:41 PM
The LT1 That Could's Avatar
i think that plug is available at napa...M22
Old Aug 29, 2005 | 09:06 PM
blind527's Avatar
Thank you. Some people told me it could be an 18M too. The bracket that held in the AIR pump can be taken out as well, correct? It's the big bulky silver bracket.
 Michael S. Palmer
Old Aug 29, 2005 | 11:49 PM
Bawls's Avatar
Sure can.
Old Aug 30, 2005 | 11:44 AM
blind527's Avatar
I just cut the AIR tube behind the header primaries and there is stuff SQUIRTING everywhere?!?!?!??!?! It isn't oil, coolant, or ANYTHING, it smells and feels like water. Is this normal? Is there just water pressure build up? Gah nevermind. I acidentally cut the A/C line which is right next to the AIR tube How do I fix that?
Old Aug 30, 2005 | 11:55 AM
WhiteSSP's Avatar
Get a new AC line, maybe duct tape.
Old Aug 30, 2005 | 02:10 PM
simple's Avatar
damn lol
you will need a new AC line, or just yank that **** too (winters coming anyway)
you should cut the AIR line where it crosses underneath the crank pulley and when its loose there, follow it up and cut it again farther up on the passenger side
Old Aug 30, 2005 | 11:10 PM
97LT1's Avatar
That sucks.
Old Aug 30, 2005 | 11:46 PM
blind527's Avatar
Meh, it happens I'll get over it
Old Nov 15, 2006 | 08:28 PM
C_Rules's Avatar
what do i use to block off the connections to my aftermarket headers? you know the piece that looks like a stem sticking up from the header. do i use the same plates that were used to block off the egr exhaust gas feed pipe in the back of the intake manifold?
Old Nov 15, 2006 | 08:32 PM
Snyper's Avatar
...go to napa and get pipe fittings..the brass ones are the ones I used..and they worked fine.
Old Nov 16, 2006 | 11:26 AM
Bawls's Avatar
I think you use the search button to block those connections off.
