Need help car running bad and rich
Old Sep 4, 2005 | 06:07 PM
whinton23's Avatar
Default Need help car running bad and rich
Ok here is the deal broke starter at the track last night and had it towed home. Got the new starter on and know the thing wont start unless you crank the **** out of it. Then when you do get it to run it runs fat i mean real fat. So just out of spite I tried starting it and just pushed on the gas a little bit and it started right up. So is it my TPS or what could it be. I need any input.
Thanks
Billy
Old Sep 4, 2005 | 06:14 PM
whinton23's Avatar
By the way this is what the car has done to it.
1995 LT1 A4 White
LPE Cold Air, Hot cam Kit,Hooker Cat Back,Pacesetter LT,1.6rr,342 gears,posi unit,LT4 Knock mod,NGK,MSDcoil and wires.30lb injec and 52mm throttle body
