Question for Guys/Gals Running 396s?
Old Sep 4, 2005 | 08:34 PM
METALBEAST's Avatar
Default Question for Guys/Gals Running 396s?
Has anyone ever ran into a machine shope that would NOT do the machine work for fear of hitting the water jacket due to machining for clearance? I know more clearanceing when machining a 396 vs a 383 but is this really an issue?
Old Sep 5, 2005 | 02:40 AM
sssalah's Avatar
Depends on the rods, some rods are profiled loe in the bolt area for better clearancing, example is the Lunati pro mod and the eagle h-beam which i run. I've seen how much clearancing was done to clear the rod bols and it was not much.
Old Sep 5, 2005 | 09:29 AM
Tony Shepherd's Avatar
A simple block fill is almost a must for a 396. Even if you dont break through the water jacket.....it will be thin. Most people just block fill the lower half and be done with it. I block filled half my block for strenght.
Old Sep 5, 2005 | 11:46 AM
Carbed4thGen's Avatar
Can u daily drive a block that is filled? or will you have some cooling issues?
Old Sep 5, 2005 | 12:47 PM
dhdenney's Avatar
My block is not filled and not had any problems so far.
Old Sep 5, 2005 | 10:56 PM
You can do a partial block fill and have no issues. Mine is half filled and I dont have any cooling issues.
Old Sep 6, 2005 | 10:10 AM
Race-Prep's Avatar
Suspended Sponsor
Filling the block is really not an issue, we do the 396's fairly often and have never seen a problem, however if you use the Eagle rods with the L-19's you could have issues as they are a much taller bolt head and the can penetrate the water jacket. I usually leave the fill for the "racing only" engines.
-Bryan
Old Sep 6, 2005 | 10:21 AM
N20Dave's Avatar
Ours was not filled last year and there were no issue. It is half filled now but I haven't run it on the street yet so i don't know how it will be.
Old Sep 6, 2005 | 11:37 AM
METALBEAST's Avatar
Guys, thank you very much for your responses!
