GM LT4 HotCam
Old Sep 6, 2005 | 10:00 PM
hybrid_malibu's Avatar
Default GM LT4 HotCam
DO the LT series cam's have distributor gear drive's on the back of them? I am looking to install one in a ZZ4 block.
Old Sep 6, 2005 | 10:34 PM
ak95ta's Avatar
Yes they do. Even though LT1 engines do not have a rear distributer, the do have a stub shaft that drives the oil pump. The LT4 hotcam will fit in any 87' and later SBC roller cam engine. You must make sure your ZZ4 block is setup for a factory roller cam in order for it to work properly.
Old Sep 9, 2005 | 09:04 PM
Thanks for the information.
Old Sep 9, 2005 | 09:34 PM
94Z71's Avatar
actually, that cam will fit in any small block made. the ZZ4 has to be a 1-piece rear seal block in or to use the factory roller cam hardware.. if not, retro-fit "link-bar" roller lifters, and a cam buttom must be used.
