Spec clutch problems?; also running lean and having misfires
Old Sep 8, 2005 | 04:27 PM
1QwickLT1's Avatar
Default Spec clutch problems?; also running lean and having misfires
Whats up guys, I just had a few questions......First off, i just installed a Spec Stage III (back order from thunder racing and took 3 weeks ) So I got it installed (my second aftermarket clutch) but when I started it up to put it in reverse, i noticed it didn't grab at the bottom like the centerforce did?? I thought maybe I didn't bleed the air out all the way, so i did it again and nothing changed. It goes into gear and everything OK, but I just didn't think it was normal. What do u guys think? Is it gonna last like 100miles or what? The flywheel has been resurfaced twice for the record.
Secondly, I have the mods in the sig with a stock tune (i know i know, im a broke college kid, what can i say?) I know I need a tune, but I think im going to need injectors too?? The car runs real lean all the time and has random missfires. and just today my SES like started to blink and the car seemed like it wanted to die and was peeged at lean. my question is this, before i get a tune do i need to get injectors, adustable fuel pressure regulator, or what? I have had the H/C in for about 5k with no tune ( i know i know )
Any help would be awsome and ask any questions if u need.
Thanks, Dave
Old Sep 12, 2005 | 02:07 PM
1QwickLT1's Avatar
Hmmmm, I guess thanks for all the input guys
a lot of views but no posts??? C'mon guys
Old Sep 14, 2005 | 04:41 PM
1QwickLT1's Avatar
................???? nothing...................???? C'mon people!!!!!
Old Sep 15, 2005 | 04:56 PM
PipesTA's Avatar
How much has been taken off your flywheel? Only in reverse is your clutch doing this?
Old Sep 15, 2005 | 10:10 PM
cam75w/ls1's Avatar
Default Running lean....
Just to let you Know that I've already fixed two LS-1 engines for customers running lean. One had a stopped up fuel filter and they kept driving it and melted a hole in the piston... the other melted several from bad mass air flow meter. Be careful....Also, did you have the flywheel machined on this spec clutch??? You may be too thin and need flywheel shim to bring the pedal up.
Old Sep 15, 2005 | 11:48 PM
Heatmaker's Avatar
Spec may make good clutches for other manufacturers vehicles, but thier F-body line up lacks quality.
I always had a problem with thier clutches and never had one last more than 2K miles without going sour or causing problems.
I had the exact same problem after installing a SPEC stage 2 clutch... and even installed a new flywheel. The only true way to solve the Reverse gear lock out issue is the install an adjustable Master cylinder, and bench bleed the hell out of the haudraulic setup. I'm using a ram adjustable that cost like 170 bucks and it does an amazing job. I'm not trying to discourage you or anything... but you can't expect much from a Spec clutch... they have serious quality issues. There's so many guys over at Cz28.com that have had faliures with that clutch that it's unbelievable.
Old Sep 18, 2005 | 08:19 PM
vulgardisplayofpower's Avatar
the shims start at 0.55 thousands just did mine didnt have no probs , dont break the system and you shouldnt of had to bleed system
