Need k-member help
Thanks a MILLION
Tyler
The high misalignment bushings for the A-arms should be put in the eye of the Rod end before trying to put into the K. If the bushings/spacers do not fit the rod end then you were sent the wrong size but dont see that happening since BMR uses mostly the same size bushing for everything, A-arms, LCAs, etc....
Now I did have problems with my K-member install but mine were mainly due to me trying to use solid mounts.
