Exhuast Install?
Old Sep 11, 2005 | 02:35 PM
Empire's Avatar
Default Exhuast Install?
Alright I am going to be ordering a magnaflow exhuast come monday for my 94 TA, part # is 15620. Anyways, how hard is it to install this by yourself? I would put my car on jack stands and then unbolt my stock exhuast, but does this magnaflow exhuast just bolt right on or does it involve welding? Thanks
-Mike
Old Sep 11, 2005 | 02:46 PM
Speed Density's Avatar
hashtagBMW
ur going to need ur car up about 6-7 ft, and u cant just unbolt it. ITs welded on in every place by the cat, mufler, etc. ur going to have to cut the stock exhaust out with a electric pipe saw. And you cut it to short and your new exhaust wont fit. just take it to your local exhaust shop in town.
just my .02
Old Sep 11, 2005 | 02:50 PM
Empire's Avatar
ok thanks, I think I just might go get it done by my local dude, just wanted to see if I could save myself a few bucks.
Old Sep 11, 2005 | 04:40 PM
Rebob5's Avatar
Empire : I installed my Borla catback by myself with the car on jackstands.
The catback was not to hard to install because I just unbolted the stock exhaust from tha cat. conveter, took a sawzall to the exhaust pipe before the rear end and then removed the 2 pieces. Installation was decent, the borla uses many peices that are connected with clamps, The hardest part was lining all the peices up so both exhaust tips were even. I would say maybe 2 hours to remove/install the exhaust system(s)
Old Sep 11, 2005 | 05:07 PM
Empire's Avatar
Is there any welding involved at all though, because if there is then i can't do it since I do not know how to weld?
Old Sep 11, 2005 | 09:06 PM
PipesTA's Avatar
It should just clamp together.
Old Sep 11, 2005 | 10:14 PM
Empire's Avatar
Maybe I will give it a go and if I mess up I can always go to a shop and get it put on. Plus maybe I will leave it off for a few days who knows
