Roller Rocker 1.6?
Old Sep 20, 2005 | 05:21 PM
SILVERZIP's Avatar
Default Roller Rocker 1.6?
Will The 1.6 Roller Rockers Work With A Cam That Has A 544 Lift? Can I Run My Stock Valve Covers?...how Much Boost Should I Expect? I Have A N Lt1 In A 95 Camaro
Old Sep 20, 2005 | 06:42 PM
brandboZ28's Avatar
The only thing youll have to do is clearance the support brackets on the inside of the covers. Other than that, youll be fine. Now, is that .544 lift with 1.5 or 1.6 rockers? If its 1.6, Im guessing its the cc305. If thats the case...again, youll be fine. If its with 1.5's, you might wanna make sure your springs can handle the extra lift.
