what size injectors for heads/cam setup?
the subject of injectors has come up, and I don't think the factory 24lb injectors are going to do the trick... car won't be ran over 6200-6300rpm (stock 80k mile bottom end)
are 30's over kill for this mild cam setup?
need help quick, car is under the knife as I type this.
I run 30lb injectors with raised fuel pressure. They will be fine as long as you tune accordingly.
I know tuning can take out a big part of the loading up issue with big injectors, and in some cases make in non-existent. with the increased overlap of the cam, and the larger injectors will there be a problem with some sort of "loading up" issues at idle? thought I read a GMHTP magazine that said you SHOULDN'T have problems with this if you don't go any larger than 10 to 20% bigger on the injector.
