OptiSpark Install Question
Old Sep 21, 2005 | 12:06 PM
lt1ws6power's Avatar
Default OptiSpark Install Question
Hey I am going to install a new optispark on my 97 Trans Am. But I have a question when you put up the optispark to the cam how do you adjust it so that it goes in? I heard that since its a 97 you can only fit it in one way. Is that true? Oh and do I have to adjust the timming at all?
Old Sep 21, 2005 | 12:22 PM
slowmofo's Avatar
it will only go on one way there is a notch in the pin that only allows for it to go on straight, and no no adjusting the timing .
Old Sep 21, 2005 | 12:23 PM
brandboZ28's Avatar
Just make sure the dowel pin goes in the correct slot and youll be fine. That is how you make sure the timing is correct.
Old Sep 21, 2005 | 12:35 PM
slowmofo's Avatar
oh yeah 97 didn't see that..... good find Brandbo
Old Sep 21, 2005 | 10:54 PM
buffman's Avatar
and don't use the bolts to draw the opti up to the timing cover either. It will go in, you'll just have to use a little force.
Matt
Old Sep 22, 2005 | 10:38 AM
dhdenney's Avatar
Should fully seat by hand.
