Removing the air pump question??
Old Sep 22, 2005 | 06:59 PM
BlckSnake's Avatar
Default Removing the air pump question??
When i remove the air pump, will there be any check engine lights from removing it, i have headers with no emissions fitting
Old Sep 22, 2005 | 07:08 PM
azzsmasher69's Avatar
what year car?
Old Sep 22, 2005 | 07:48 PM
BlckSnake's Avatar
1994 z
Old Sep 22, 2005 | 09:14 PM
slowmofo's Avatar
nope...
Old Sep 22, 2005 | 10:12 PM
Black97's Avatar
in a 97 z if you decided to add cats on, but your PCM is programmed for no-cats. When you add the cats and add the air pump you should reprogramme the PCM???
Old Sep 22, 2005 | 10:28 PM
Bawls's Avatar
Just keep the fuses and relays for the air pump in there and you'll be fine.
