Header Gaskets, Bolts?
Old Sep 23, 2005 | 05:11 PM
Speed Density's Avatar
hashtagBMW
Default Header Gaskets, Bolts?
Hey fellas, so i orderd my pacesetter long tubes today, i was wondering what gaskets and bolts to get to keep the headers from leaking and being PITA?
Old Sep 23, 2005 | 05:33 PM
brandboZ28's Avatar
A search would have helped you find that you will most likely want Felpro gaskets and Arp bolts. Stock bolts will work but Ive found that if you get a 12-point bolt, it makes it easier to get a box-end wrench on the bolt since its a tight fit between the bolt and the primary.
Old Sep 23, 2005 | 07:18 PM
hashtagBMW
And i can just pick up this stuff through like summitracing.com or localy?
Old Sep 23, 2005 | 07:47 PM
Nick213's Avatar
you can prolly get the gaskets at the local autoparts store i know i got mine at advance autoparts
Old Sep 23, 2005 | 08:58 PM
whynot's Avatar
shucks on overland carries both for you.
Old Sep 23, 2005 | 09:03 PM
hashtagBMW
Once again, thank you whynot.
Old Sep 24, 2005 | 12:08 AM
buffman's Avatar
I prefer a set of ARP 12pts. I"m not sure how well these gaskets would work on aluminum LT1 heads, but I've had great success w/ my Earl's Pressure Master Header Gaskets.
Matt
