Engine not getting enough vacuum after install
Old Sep 24, 2005 | 01:30 PM
Cenco Fbody's Avatar
Default Engine not getting enough vacuum after install
Hey guys, just had a 94 Opti and engine installed in a 95 a4 Z28. Now the Opti plugged in fine, but the motor wont pull more than 1" of cranking vacuum, whereas the toasted 95 engine pulled 5". Needless to say, the car is idling like s**t and isnt drivable. Anybody got any ideas?
Old Sep 25, 2005 | 01:03 AM
aintno6's Avatar
So you did a motor swap. Or just swaped an opti over from an other motor?
Mike
Old Sep 25, 2005 | 01:11 AM
fcat8187's Avatar
leaky manifold, leaking vacuum lines try spraying starter fluid or carb cleaner anything really flammable around the manifold or were you think it is leaking and liten to hear if the motor RPM changes just be careful ***** super flammable
Old Sep 25, 2005 | 11:41 PM
The motor was swapped, the engine is from a 94 and its got a reman'd Opti for a 94. I didnt do the swap, I had a shop do it. They are in over their head at this point, however, and havent got any answers. They did a smoke test and couldnt find any leaks. I'll check the lines when I get it home tomorrow, and maybe Ill try the carb cleaner. At least I have somewhere to start. Thanks guys.
Old Sep 26, 2005 | 02:13 PM
94strokedz's Avatar
I'm not positive about this, but the 95 opti I think had a vacuum line going to it to vent it, and I'm positive the 94 does not. Possibly the line was never plugged, keeping it from building vacuum pressure. I know they switched from non vented to vented, I just am not sure when. My 94 is not vented.
Old Sep 26, 2005 | 02:22 PM
94strokedz's Avatar
OK, I just looked it up. 95 was the first year of the vented opti. There is an in line and an out line going through the opti. The 94 does not have this. I bet the line for the opti which is not used on the 94 motor is not plugged. Did you do a complete swap, or just bottom end?
Yeah he mentioned something about that, but I thought he said that it was plugged. Perhaps he didnt, or plugged in something that shouldnt have been plugged in there.
Old Sep 26, 2005 | 02:24 PM
94strokedz's Avatar
Maybe he plugged the wrong side. I'd have them look into it. Good luck. Let us know what you find.
Old Oct 4, 2005 | 10:20 AM
94strokedz's Avatar
So did ya figure it out??
