Cam Other Mods
Old Sep 25, 2005 | 12:58 AM
fcat8187's Avatar
Default Cam Other Mods
i just took the motor out of my car and i had a broken rocker stud and a broken pushrod both in #1 so i have to fix that and thinkin to get the heads worked and put in a cam and a true duels exhaust with the hot-cam kit can you run the stock torque converter without an issue and are there any really odd things you have to do to put in those things like computer,fuel,O2 sensor ect. what are good sounding true duel systems to compliment cam lope? and what do they cost?
Old Sep 25, 2005 | 03:53 PM
sssalah's Avatar
You can run the stock converter but a higher stall one will make that cam shine and will have better drivability. Can't help you in the exhuast as I was running the stock one when I had the hotcam and it sounded completely different.
I recommend that you a do mail order tune as this cam is very popular and someone like pcmforless or madz should have it done very close to optimum. For the injectors monitor your duty cycle and if it's up high then go ahead and change to 30 SVO. You didn't mention headers.
