i just cant get rid of a miss
Old Sep 29, 2005 | 05:52 PM
ricknbird350's Avatar
Default i just cant get rid of a miss
my number 1 cylinder has a miss. this is what i did
1.changed injectors
2.checked compression 175psi while running
3.changed plugs
4.changed wires
5.pulled the valve cover off and everything looks fine
6.checked spark
EVERYTHINGS FINE and i still have this misfire
when i turn the key on my fuel pressure goes up to 43 then drops back down
i changed the fuel pump and its still doing it. any ideas?
i have a code 26,42,43,i need to get rid of these any ideas
Old Oct 3, 2005 | 03:54 PM
cmon anyone have any ideas?
new problem i put a new hvac unit in my car and now im not getting power to my ignition module or coil any ideas? and my windows wont work now either
Old Oct 3, 2005 | 04:04 PM
slick1851's Avatar
Dont know, Check the Opti (crap) spark out, sounds like thats it?
Old Oct 3, 2005 | 04:42 PM
Vendetta's Avatar
what is done to the car?
bump for you
Old Oct 3, 2005 | 06:42 PM
slick1851's Avatar
Bump for you also
