hesitation - something's wrong here!
Old Oct 10, 2005 | 10:24 PM
riodealz28's Avatar
Question hesitation - something's wrong here!
on my 96' a4 lt1 i step on the gas from like 25mph and it starts to hesitate to go like if somthing is holding the car and then it lets go and the car starts to go faster any idea what could be wrong ?
Old Oct 10, 2005 | 10:27 PM
Speed Density's Avatar
hashtagBMW
Thats happen to me before, then a few hours later it was gon..
Old Oct 10, 2005 | 10:30 PM
brandboZ28's Avatar
When was the last time your fuel filter was changed?
Old Oct 10, 2005 | 11:55 PM
Coders11's Avatar
I felt that awhile back right before my trans went out. I always just assumed it was a tranny problem because I haven't seen it since I put the new one in.
Old Oct 11, 2005 | 10:16 AM
Bawls's Avatar
Start with the basics:
Fuel Filter
Plugs
Plug wires
Old Oct 11, 2005 | 10:25 AM
lt1fbody355's Avatar
Mine was doing the same **** it was the o2's
Old Oct 11, 2005 | 10:34 AM
satinleafct's Avatar
OFF-TOPIC:
What kind of hood do you have on your car?
Old Oct 11, 2005 | 10:50 AM
The LT1 That Could's Avatar
fuel or ignition related....as little as a fuel filter, as much as an opti. is the car throwing a code??
do a basic tune-up; plugs, wires, fuel filter. If that doesn't fix it. I would start looking into your ignition system, and possibly point the finger at the opti!
Old Oct 11, 2005 | 10:27 PM
riodealz28's Avatar
i changed my fuel filter like about 14,000 miles ago do yall think i should changed it agian and i changed my plug's and wires like 3 month's ago could it be the coil and if its the coil should i get it stock or msd ?
Old Oct 13, 2005 | 12:24 PM
dhdenney's Avatar
Well 14,000 miles isn't time for a new filter necessarily but it has enough miles that it could be dobbed up. I would check fire on all 8 cyls first because it won't cost anything--just time. I had a friend who was having performance issues in his truck and I said try the fuel filter. He replaced it and that wasn't it. He checked his plugs and he had a dead one. Case in point, it could be a few things so start with some simple diagnostics. On the coil, I had a MSD Blaster once and it only lasted 10,xxx miles or so. I like MSD stuff but I would go with a different coil here. I don't think stock would really lose you anything.
Old Oct 13, 2005 | 09:49 PM
riodealz28's Avatar
i checkt my car today at autozone with the the diagnostics thing and it said my o2 sensor was out the sensor before the cat, i think its the manifold sensor right, could that be the problem ?
Old Oct 13, 2005 | 11:00 PM
slowmofo's Avatar
Old Oct 14, 2005 | 09:05 AM
dhdenney's Avatar
Manifold sensor right??? Oh, I guess that's what the computer thingie called the O2. Here's a little trick, try unplugging the O2s and the car should stay in open loop (I'm not 100% sure though). If it fixes it, then it's the O2. If you plug it back up and it starts crapping out, then it's getting bad data when it goes back into closed loop.
