Spring pressures
Old Oct 14, 2005 | 07:05 AM
Formula_LT1's Avatar
Default Spring pressures
Just curious for personal reference, does anyone know buy the card that comes with the valve springs how much pressure (open and closed) do comp cams 918 springs have? I've browsed around on comps web site, looked on summitracing.com, and actually tried to call comp cams with little results.
Old Oct 14, 2005 | 06:52 PM
transamtom's Avatar
Right off the box.Part #26918-16
Installed 130lbs@1.800"
Open 318lbs@1.200"
Spring Rate 313Lbs/inch
Coil Bind 1.085
Old Oct 14, 2005 | 07:03 PM
Thats alot man.
Old Oct 14, 2005 | 07:04 PM
transamtom's Avatar
No problem.
