A4 to M6 swap
Old Oct 19, 2005 | 09:48 PM
93BlackZ28's Avatar
Default A4 to M6 swap
Just wondering how much the swap is and what parts are needed. BTW i did try a search.
Thanks.
Old Oct 19, 2005 | 10:56 PM
PipesTA's Avatar
I got all the parts out of a 94 for my swap. If I remember correctly, I paid about 1200 and that was with a Spec Stage 2 clutch. You'll need the trans, bellhousing, flywheel, clutch, pedal assembly, clutch cylinder/resevour, shifter, M6 crossmember, lower shift boot and a 6 speed console. You'll also need a tune to make the PCM t56 friendly since your speedo will be off. Don't forget the reverse light plug, speedo plug, and reverse lockout plug off the M6 harness. I followed this write-up and did it myself in my garage on jackstands. I took my time and it took me about three and a half days to complete. Just need to make sure you have everything.
http://www.afrashteh.com/tranny_pics/T56.htm
Don't get scared away. It's definatly do-able. It's all bolt-in. Just be sure to take your time.
Old Oct 19, 2005 | 11:14 PM
Saad06's Avatar
i did the swap, and then some... i swapped a 97 LT1 + T56 to my 94 4l60, was not that hard... i did it in a few weeks, theres a little rigging and cutting involved..
i dont know the price cuz i got it for free from a donor car!.
Old Oct 19, 2005 | 11:27 PM
Empire's Avatar
Lucky Punk
