tps circuit high
Old Oct 22, 2005 | 09:56 PM
ricknbird350's Avatar
Default tps circuit high
well my tps circuit is high apparently and i changed it still didnt fix the problem. i drilled the holes out on one and made it adjustable and no matter what i set it at it still throws the code. anyone have any idea what the heck is goin on?
Old Oct 22, 2005 | 11:35 PM
buffman's Avatar
your voltage at WOT needs to be less than 4.8 volts. More or less voltage at 0 % TPS doesn't matter because the PCM equates that voltage to zero when you start the car. It's the 100% TPS value that matters.
Matt
Old Oct 24, 2005 | 07:48 PM
what if the voltage for the tps is within spec and it throws a code for tps cicuit high?
Old Oct 24, 2005 | 08:36 PM
buffman's Avatar
could be a faulty TPS sensor. I only recommend AC DELCO sensors
Matt
