o2 Sims
Old Oct 25, 2005 | 09:21 PM
joshua32's Avatar
Default o2 Sims
What is the best place to get some o2 sims for my 95 T/A?
Thanks
Joshua
Old Oct 25, 2005 | 10:23 PM
AJB96TA's Avatar
Try Afterthouhtsauto.com They have pretty decent price on 02 sims.
Old Oct 26, 2005 | 02:58 PM
slow96z's Avatar
I'll sell you mine for $50. Do you need the flat plugs or the square plugs? Mine are for the LT1 but Summit sent me some that didn't fit my car. I see you have a 95 and mine's a 96 look at the plug first. They told me the flat plug was for LS1 only, but it was the only one that worked on my car.
You could also have my guy tune the car for you and delete the rear 02 sensors. He charges $100 for a base performance tune. This will also tune out the skip shift.
Old Oct 26, 2005 | 03:00 PM
joshua32's Avatar
Let me get back to you on that...I'll have to check the sensors and see what type i have...thanks
Joshua
Old Oct 26, 2005 | 03:01 PM
Chris 96 WS6's Avatar
Casper's electronics is another sponsor here that carries them.
Old Oct 26, 2005 | 06:34 PM
96capricemgr's Avatar
O2 sims are ONLY for the after cat position on 96+ cars. Putting them in front of the cats would at best make the car run like crap till the pcm set a O2 code or could possibly do engine damage.
The ones in fron t of the cats are to allow the pcm to monitor part throttle air fuel ratio, the ones after the cats on 96+ cars are just to set a CEL if the cat stops working that is the one and only thing they do they have zero impact on performance.
