problems with new car, bogging down
Old Oct 26, 2005 | 03:11 PM
groundpoundinlt1's Avatar
Default problems with new car, bogging down
got a 96 t/a and previous owner said it was having some prblems with the egr but he also told me all of it was deleted out...anyways the car was running fine then just quit....you go to crank it and it does nothing but trys to turn over..NO FIRE....if you gas it it will halfway run, smoking like hell, choppy then bogg itself down..if you try to ease out of the clutch it will bogg down...any ideas..i need to get this thing off the side of the road!!!
Old Oct 26, 2005 | 03:55 PM
blkchevyz's Avatar
that could be many different things.
first thing i would look at though would be the maf connection.
Old Oct 26, 2005 | 04:44 PM
joshua32's Avatar
I had a similar problem with mine...was running like **** with similar problems that you described. In the end it was a $8 part from O'Reilly. I believe it was the coolant temperature sensor (the one that mounts on the water pump) anyway, I replaced the connector and it solved my problem. Good luck
Joshua
Old Oct 27, 2005 | 12:32 AM
Blown_Red_97z's Avatar
It sounds like the opti. When 1 of my optis went out, it just died on the freeway. When I got it in the garage at home, it would just crank but never turn over. If I applied some throttle, it would kind of start, and chug a bit, then die again, all the while the garage was being filled with white smoke.
Old Oct 27, 2005 | 10:50 AM
stevemilz's Avatar
I agree with blkchevyz
Old Oct 27, 2005 | 05:05 PM
ok a little update...car still running like ****...i unplugged the maf with the car running and it cleared up and seems to be running fine with the occasional pop, i guess where the maf is unplugged...thing is i tried another maf from another one of my cars and it starts acting retarded again and running rough...any suggestions???
Old Oct 27, 2005 | 05:11 PM
blkchevyz's Avatar
try messing with the connector and see if it does anything different. i broke a wire loose on mine and it would still read just not correctly.
Old Oct 28, 2005 | 02:24 PM
wires seem fine...anything else??
Old Oct 28, 2005 | 02:59 PM
94strokedz's Avatar
Mine did the exact same this past spring. Ran like poop, smoked like hell, hard to start, and stalled when I put it in gear. Ended up being bad gas. Put a 5 gallon container of Premium, ran like a raped ape!
Old Oct 28, 2005 | 03:03 PM
i dont think it could be bad gas as this car was driven and didnt sit for a long period of time
Old Oct 28, 2005 | 03:12 PM
94strokedz's Avatar
Could be condensation from in the tank at the gas station(in ground). Especially being that there has been a few very cold nights, atleast here there has been. Its possible, not likely, but very possible. There is a gas station by me that I wont go to because my car almost always runs like crap on their gas, especially when its cold at night. Good luck.
Old Oct 28, 2005 | 05:51 PM
but it runs fine when the maf is unplugged....so the fuel must be fine to run normal with it unplugged
Old Oct 28, 2005 | 05:53 PM
blkchevyz's Avatar
seems like it would be something in the wiring harness if it runs fine without the maf plugged in, and replacing the maf didnt help.
Old Oct 28, 2005 | 05:56 PM
but i dont know of wiring harnesses goin bad or do they...think this could be computer related...the car has a pcmforless tune....
Old Oct 28, 2005 | 05:58 PM
blkchevyz's Avatar
did it start happening after it got tunned?
i would try and find a scanner and check to see what the maf is doing
Old Oct 29, 2005 | 11:27 AM
slowpoke96z28's Avatar
i'd get a scan tool and see waht the MAF is doing and for now leave the MAF unplugged and let the car run in speed density mode.
Old Oct 29, 2005 | 12:31 PM
will it hurt the car at all to run/drive without a mass air?
Old Oct 29, 2005 | 02:17 PM
slowmofo's Avatar
no it won't the car is in limp mode right now, will run rich but fine
Old Oct 29, 2005 | 02:21 PM
ok well, will it throw a code with no SES light?? any other ideas on whats wrong with the car
Old Oct 29, 2005 | 02:52 PM
2MuchNos93LT1's Avatar
My bet would be the fuel pressure regulator.
