What Cam to Get?
Old Oct 27, 2005 | 08:30 AM
94'BLKBRD's Avatar
Default What Cam to Get?
1.what Would Be A Good Cam For My Car With My Mods?
2.if I Get The Le1 Heads With The Gm847 Cam Would My Car Be Streetable And Would I Have To Change My Internals?
Old Oct 27, 2005 | 06:27 PM
slowmofo's Avatar
if your comp springs are good to .600 lift, you will be close the 847 on a 1.6 is 575 595 lift. 93 94's came with hardened pushrods, but I replaced mine anyway when i put my 847 in..
Old Oct 27, 2005 | 08:30 PM
2MuchNos93LT1's Avatar
very streetable sounds like you want to be fast real fast.
Old Oct 27, 2005 | 09:02 PM
Quick96ss's Avatar
what about a lt4 hot cam and the le1 heads or should i do the le2 heads? what will i see for performance?
Old Oct 29, 2005 | 03:00 PM
Dont get no other cam besides the Gm 847 part number 12370847 or the CC 306
Old Oct 29, 2005 | 03:14 PM
groundpoundinlt1's Avatar
the hot cam is a waste of time and money as far as power gained....the 847 and 306 cams are good cams but have you looked into custom grinds....for best gains having a cam match your heads(flow #s, CC, etc) is the way to go....
