Lt1 which year?
Old Oct 28, 2005 | 09:42 PM
RoAdRaGe912's Avatar
Originally Posted by sparky t/a
i have a 1993 formula. it has a 700r4, it came that way from GM.
unless it was some kind of early 93 thing that i don't know about then it has a 4l60 (not 4l60e)
4l60 was hydraulically controlled and the 4l60e is electronically controlled, hence the e at the end
edit-
The trans is a 4L60, which is a 700R4 with a different connector and extra check ball in the valve body.
Old Oct 28, 2005 | 09:58 PM
OverLord's Avatar
Thx for the info man, i just tought it would be cheaper to do just bolt ons and n2o, But i will think about and save more money.I think i am gonna look for a 95 hopefully for about 3-5k. I will have to sleep on this. What times are all bolt ons runing? mid 12's?
Old Oct 28, 2005 | 10:05 PM
has everything to do with the setup. i know of stock stall, stock cam cars that have gone 12.7, but a lot of people are still mid 13s or higher with even a decent amount of bolt ons.
suspension is key.
also since you're getting a TA, check out the thread below for information about the spoilers on TAs as they vary from the early years if that's important to u. i'd never have a TA with a molded spoiler (at least for long).
https://ls1tech.com/forums/lt1-lt4-modifications/401176-spoiler-high-low.html
Old Oct 29, 2005 | 09:13 PM
sparky t/a's Avatar
http://www.angelfire.com/ga/cincity/
http://www.firehawkowners.com/owner/1102.html
http://lt1tech.com/cgi-bin/ultimateb...c;f=7;t=000066
http://speeddensity.org/showthread.php?t=666
Old Oct 30, 2005 | 10:22 AM
matrik's Avatar
I love my 97, especially with the newer interior and gauge cluster. Besides, how many 97 formula ws6's do you know of with cloth interior and a hardtop . ObdII is more annoying when it comes to throwing codes, but atleast i can get them scanned at any autozone if I don't have autotap with me
Old Oct 30, 2005 | 11:40 AM
Vendetta's Avatar
what exactly is a "daily race car"
Old Oct 30, 2005 | 12:13 PM
Speed Density's Avatar
hashtagBMW
Default ...
lol, what is a daily race car? Like a Top fuel dragster that you can drive throught Mickey Ds? Or like an Fbody with a **** load of power and *****, thats going to get you to wherever you need to go, and it will be in style?
Old Oct 30, 2005 | 05:41 PM
OverLord's Avatar
what i meant by daily race car, is something i can drive to the drag strip run mid 11s to mid 12s on pump gas, drive it back home and take to school everyday. Sorry for the confusen.
Old Oct 30, 2005 | 06:10 PM
hashtagBMW
Well i hope you have a good job, if your still in school and you want 11s you must be wealthy.
Old Oct 30, 2005 | 06:17 PM
Camaroz's Avatar
13$/hour i think he said from the last thread.... compared to my measly 7$ an hour hes rich
Old Oct 30, 2005 | 06:20 PM
hashtagBMW
Damn............ u are a rich one.
Old Oct 30, 2005 | 08:11 PM
  #32
BizZzatch350's Avatar
Moderator
97, down here they dont have to pass the sniffer
Old Oct 31, 2005 | 03:12 PM
  #33
OverLord's Avatar
I wouldn't call me rich but i can mange all the bolt ons (hope fully and a tune) and maybe a 100-200 shot.
Old Oct 31, 2005 | 04:20 PM
  #34
hashtagBMW
Ok, good luck with the Bolt ons, But i would not recomend runnin a 200 shot into a stock block, ur going to see some troubles with that. Have you found a car yet?
Old Oct 31, 2005 | 08:01 PM
  #35
slowmofo's Avatar
93's came with the 700r4 NOT the 4l60e, and the "early" 93 m6 cars got the same t56 as the Viper, same tranny different gearing......
Old Oct 31, 2005 | 08:03 PM
  #36
97blkz's Avatar
I say 97, newer style tail lights and interior!
Old Oct 31, 2005 | 08:08 PM
  #37
Vendetta's Avatar
Technically you're wrong. They had a 4L60, not the 4L60E. It was a hydraulic tranny, basically the same as the 700R4 but GM changed the nomenclature.
Old Oct 31, 2005 | 08:33 PM
  #38
if you would have read i already cleared up the 700R4/93 thing.
the t56s in 93 were available with two different gearing types dependant on which rear gears the car came with. there was a difference in first and final gear ratios. i wouldn't think that the viper would have the same input or output shafts either.
Old Nov 1, 2005 | 02:57 AM
  #39
97M6Formula's Avatar
I was lazy and didnt read posts so sorry if I repeat but here is what I think... 95 is the best year.... I have a 97 btw.. But here is why... 95s have the vented opti for one thing less probs. They are obd 1 which means tuning software is WAY cheaper.. They are single cat which means its easier to take it out or cheaper for some headers. It has all the benefits of a 97 without having the obd2 pcm. If you are going to leave it stock then get a 96 or 97 if not buy a 95
Old Nov 1, 2005 | 06:41 PM
  #40
OverLord's Avatar
hey how much does it cost to build a 396 lt1 and install. (if you do no work.)
