end gears
Old Nov 2, 2005 | 05:33 AM
old and good's Avatar
Default end gears
how can i see if a car has 3.23 gears or 2.71? without having to check it the hard way
Old Nov 2, 2005 | 08:43 AM
roughneck427's Avatar
look in the glove box for the rpo codes
gu1 2.41
gu2 2.73
gu3 3.08
gu4 3.23
gu5 3.42
Old Nov 2, 2005 | 10:24 AM
RedRocketZ28's Avatar
Can't you also tell by what the lowest gear you can put the shifter in is? If you can put it down in 1 then you have 3.23s and if you can only go down to 2 then you have 2.73s.
