Miss Fire
Another thought was the the spark might be retarded... not exactly sure. Anyone else had this problem with the LT1's.
At about 50000 we had the crank trigger replaced because the waterpump was leaking back on to it and causing it to miss under any load, but it never back fired then.
...to the person who said opti is for optimum.... uhhm, no. and they don't use them on LS1's either.
it's called an opti because the distributor uses an optical sensor inside it....
Any recomendations on some good wires, MSD? Any others?
If this happens again, is there anyway I can reset the computer so it will work. Will pulling the positive side of the battery loose reset it and shut that off if it happens again?
It almost sounds like it is leaning out! But usually when a motor is leaning out, it revs up high just before it dies. So I dont know.
Also the car for the past little bit has had some trouble starting sometimes. It will just turn over and try to light and sometimes it will fire up and immediately stall out. Then when I try again, it will light right up and run fine. I am wondering if there two things are connected?
Some one told me that the reason that the car wont start like that is due to a lazy oil pressure sending unit. When the computer is reading low pressure it will not alow spark. I thought about that some more later, and that makes absolutly no sense. If that was true, how would the car start after and oil change? When you fire a car up after an oil change there is no oil pressure for about 3 seconds, then you hear a click and the pressure gauge jumps up.
If you think it's leaning out, hook up a scan tool and check the fuel trims and O2 readings.
