Autometer Tach with shiftlight
The green wire can go to the - wire on the coil, or the better place to use is the A13 (correct me if I'm wrong and it's not that one on an F-body) pin on the PCM. All you need is a $.20 pin from the dealer, crimp it on the wire, stick it in there, and run the wire to your track. No splicing into the coil wire
Matt
