FEL-PRO gaskets
Old Nov 10, 2005 | 06:13 PM
SPACECITY's Avatar
Default FEL-PRO gaskets
Does fel-pro make a gasket rebuild kit for the LT1's ??
Old Nov 10, 2005 | 06:17 PM
Klortho's Avatar
From what I have seen on the Fel-pro site, if you want a complete gasket set, you need the head set and the conversion set. This will get you every gasket needed.
When I priced the head set, it was around $188 and the conversion set was like $60 or so.
Old Nov 11, 2005 | 02:43 PM
SPACECITY's Avatar
What in the world is a conversion kit??
Old Nov 11, 2005 | 03:58 PM
SPACECITY's Avatar
Also, Is fel-pro head gasket the same thickness as the stock ones??
Anyone know what stock thickness is??
Old Nov 11, 2005 | 06:58 PM
dhdenney's Avatar
Summit has complete gasket sets for the LT1. I bought one about 4 years ago and they were expensive then but don't know about now.
Old Nov 11, 2005 | 08:16 PM
TwoFast4Lv's Avatar
Fel-pro 1074's are .039. stock is like .054.
there are different versions
Old Nov 11, 2005 | 09:13 PM
Klortho's Avatar
The Fel-pro numbers you need are these
HS9966PT Head set
and
CS9966 Conversion set
Basically every gasket needed to completely regasket the entire engine. The oilpan and valve cover gaskets will be their Perma-dry gaskets (very good rubber) and the Head Gaskets will be the 9966PT ones
Old Nov 16, 2005 | 07:42 PM
Cheater's Avatar
i had those gaskets ,but the valve cover gasket always leaked oil on my hooker lt so i bought som gm gaskets and it stoped
 Michael S. Palmer
