help with GEARS
I was thinking about ordering the gear package from thunderracing with the girdle and stud kit and all that but I got to thinking that the actual problem if something was to snap would be the ring and pinion right? So shouldn't I just save myself hundreds of dollars and replace the ring and pinion??? It seems like a very basic question with a simple answer..for a simple reasons...but I never really thought about it to hard.
thanks for your replies!
Well the main drawbacks to the 10bolt are as follows (in no particular order):
Posi unit strength
axle strengh
Pinion shaft diameter gets dangerously small with numerically higher gear ratios
So in essence, replacing the ring/pinion and posi would do nothing besides delaying the inevitable with hard launches on stickies (especially with a hard hitting stall, manual, and even more so with spray). I would just save my money to get that 9"/ 8.8" rear end with 35 spline axles and the works.
Posi unit strength
axle strengh
A 12 bolt is not enough to handle severe abuse at the track. Look at all the ones breaking. A 9" is much stronger and has much stronger axles available, posi units, pro gears etc. The 8.8 is also very strong, a relatively new option that kicks the **** out of a 12 bolt. The 12 bolt, while better than the stocker, is a waste of money considering the stronger 9" is the same price. Drawbacks include ABS compatability, Traction control loss, etc.
they are much stronger and alot better to rebuild, plus you can swith third members for quick gear changes for the strip.
