LT1 > LS1? Some ideas why...hehe
A lot of LS1 guys are going with iron blocks.
LT1's are junk and you should all give yours to me, the junk collector.
I think your mistaken. Jeff Green from Indiana (guy who I mentioned earlier) is the sole man who converts Donovan 400 SBC blocks into LT1 blocks.
Check the specs on these blocks you guys are claiming to be LT1 blocks. There is a difference between a Gen 1 and a Gen 2 block.
Matt
When people say that all the new cutting edge technology is coming out for LS1's I smirk. All the 'new' products coming out for the LS1 have been around for gen 1 sbc motors for awhile now. So one could conclude that since you can put gen 1 parts in an LT1, our aftermarket is potentially larger, as long as you have the money to convert things. Just my opinion, however.
opti vs the coils.
Iron vs aluminum
these two things doesnt make the ls1 superior. but the opti is a bitch and the heat from iron is redicules. and I really dont agree that the lt1 has a better aftermarket than the ls1. How many sites do your find thats based on lt1 only? But this is like inport vs demestic..... its never going to end. Its all based on what YOU like.. and if it makes you happy go for it. b/c there is always somthing faster.
If you are convinced the opti is so terrible there are alternatives so scratch one "problem" on the second the comment about iron and heat you just demonstrated how little you understand about how an internal combustion engine works. Aluminum pulls heat out of the cylinder into the cooling system where it is waste ideally all heat generated would be kept in the cylinder and used to expand the gasses and drive the piston. Reallity does not allow this though so we have to deal with some heat loss into the block and heads.
I theory I will believe the LT1 using gen1 race parts should have a higher capability but the question becomes when does it stop being an LT1. Do we lump the gen1 and gen2 together since they are frankly SO VERY similar and go from there or do we define it as capable of running a timing set driven waterpump and opti even if the opti is not used for the spark just the optical pulses?
I run into a lot of guys at the strip that blow off the LT1 as junk with some mods over the last few months though my "junk" is getting to be faster than some of the mildly modded LS1s and does so in a Caprice not in a f-body she is gaining respect.
amen brother......... my bro has an ls1 car and he owuld knock my dick off if we raced.......... but i love my f body...... and that is all that counts
