LT1 overheating... little bit wierd. Help
It is a 96 LT1 trans am.
I checked all three relays. All good. The 2 fuses are good. All grounds are good. If i jump the relays, the fans kick on. If the car is running, and i umplug the engine coolant temp on the water pump (so the PCM thinks the car is like 300+ degrees), in a short time both fans kick on.
Other wise the fans seem to never turn on. I can watch my gauge go to something like 230 degrees... and occasionaly it will creep back down to 190's. So im thinking the ECT sensor is bad.
What else can i do to figure out why my coolant fans are not turning on? And is this the sole reason my car could be over heatings in stop and go traffic? Does it douns like a ECT sensor?
THanks
NIck
The absolute cheapest way to fix it would probably be a mail order tune. Check out pcmforless.com or madz28.com. I think either of them will do it for about $50 if that's all you want changed.
EDIT for my stupidity and not reading your post all the way..
is there a LT1 edit type of thing that i can drop some cash on and do it myself?
Thanks
Im willing to drop the cash if you think i will be able to teach myself so that it will actually do me some good! lol.. thanks!
but thanks for the info... if i dont go with a mail order tune... i'll have to get tuner cat or something. I wont stand for my car even getting near 210 degrees.
The biggest thing with tunercat is that i feel that i won't be able to do anyhting but those few simple things like speedo calibration, speed limiter, and stuff like this fan thing. I don't have ANY experience with anyhitng like it. So it is a completly new experence for me.
and how much total am i looking at for everything i need for the tuner cat on OBDII?? $300? least it says that here http://www.tunercat.com/tnr_desc/Pricing.html
