Timing chain
Old Nov 24, 2005 | 09:11 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Default Timing chain
Hey guys,
I'm putting a Meziere electric water pump on my 94. I'd like to change the timing chain & gears. Being that I'll no longer need the water pump drive gear, I'd like to use a standard dual roller timing chain set. Two questions:
1: Will I have any problems with the Optispark drive?
2: How do I block off the timing cover water pump drive hole?
Thanks!
71 Monte Carlo SS454 496 CID, 600HP
94 Formula project
89 Firebird banger
Old Nov 25, 2005 | 12:09 AM
sssalah's Avatar
1- Assuming this is for the 94 FB, then no the non vented opti wont work.
2- I welded the timing cover, some use expansion plugs.
Old Nov 25, 2005 | 06:59 AM
Paul Bell's Avatar
Thanks.
I have some time for this and will be using the MSD Optispark unit when it's out next month. Looks like I'll be using a LTx timing chain set?
Any other ideas?
94 Formula project
89 Firebird banger
