Does a collasped lifter hurt?
Old Dec 8, 2005 | 07:41 AM
fastlt1's Avatar
Default Does a collasped lifter hurt?
I have one lifter bearly pumping any oil to the rocker and it is pecking. I searched and came up that it was collasped but I have some more questions.
1. Will this cause a small miss?
2. How much will this hurt power?
3. Will running it like this hurt the engine?
Old Dec 8, 2005 | 01:05 PM
harvickgm's Avatar
yes to all of the above, the lifter, if collapsed isnt opening the valve all the way, hurting performance, and cause a miss due to not enough air in the chamber for a good combustion or not getting the exhaust out and contaminating that fresh air for a good combustion. if the lifter is coming apart you could do more damage to your motor.i would replace them and be done with it....
Old Dec 8, 2005 | 01:34 PM
fastlt1's Avatar
What would you replace with? Stock or aftermarket?
Old Dec 8, 2005 | 01:40 PM
harvickgm's Avatar
look on ebay, comp cams makes a set of OEM and high performance, but i think you only need OEM replacement so, youll be good with those
