pilot bearing
Old Dec 9, 2005 | 09:54 AM
NOTAV6's Avatar
Default pilot bearing
ok found i pilot bearing from lakewood is it any good i also need pressure plate bolts (just bought arp pro series flywheel bolts for the flywheel) is the arp pro series pressure plate bolts worth getting to
Old Dec 9, 2005 | 10:54 AM
95 TA - The Beast's Avatar
The LT1 flywheel/pressure plate setup uses a completely different type of bolt vs a standard SBC clutch, so the ARP pressure plate bolts will not work...
Just reuse the stock ones, make sure you adhere to the torque spec on them... If you over-torque one of them, go to a dealer a buy a new one as you don't want it to snap while in use (happened to a buddies buildup, as he overtorqued one, the figured out he was using the flywheel spec by mistake, undid it and torqued it to the right spec, but within 500 miles that bolt snapped)...
Also, for a pilot bearing, you can just buy the truck V8 roller bearing from a GM dealer for about $20... GM put them on HD trucks and it is listed as an 'upgrade' replacement for HO V8s, including the LT1...
Old Dec 9, 2005 | 05:48 PM
NOTAV6's Avatar
ok well heres the pilot bearing i got should i have any problems if anyone has any experience with this particular one
http://store.summitracing.com/defaul...=egnsearch.asp
