Timing chain question?
Old Dec 9, 2005 | 07:49 PM
97SprChrgd383's Avatar
Default Timing chain question....
I want to upgrade my timing chain. I was looking at the billet double roller timing chains. I have a pretty aggressive setup so what would you guys recommend? Also, does it have to be lt4 specific or is it just the sbc bbc timing kit?
Will this fit http://cgi.ebay.com/ebaymotors/SB-Ch...spagenameZWDVW
Old Dec 11, 2005 | 07:07 PM
lafnlt1's Avatar
sure you can use this timing chain on ebay but you will have to run an electric water pump because there is no drive for it. You might also have to clearence the front cover, i did not when i did mine. also it will have to be a vented opti set-up with the updated cover for the opti to work with the timing chain.
Old Dec 11, 2005 | 09:14 PM
I have an electric water pump. And I have the vented opti, so I think I am good on that.
