Lt1 Valvetrain noise
I got a 1996 z28 and I just recently noticed a noise coming from the valvetrain. I would not consider it ticking or knocking but kind of like a rattling tick. If I snap the throttle like three times quickly and let the rpms drop I hear it, also if I open the throttle slowly it will do it prolly from 1000 to 1500 rpms and kind of die away if I keep accelarating. I do not think it is a lifter but maybe a loose rocker because the noise sounds like it is coming from the top of the motor, like the valve cover. Would a bent push rod do this if i rev'd to high, and could the rockers just have loosened up or worse? Are my stock rockers adjustable or non-adjustable? I heard that you dont have to go through the great task of setting valve lash but rather just torquing them all to the same and being done with it, but I do not know. What is the proper procedure I am going to have to do, to tighten the rockers right? Please help, thanks.
Also, I just threw a P0300 (multiple/random cylinder misfire) could this problem have caused a slight miss because I have done the opti, plugs, wires, and ICM?
