Overheating Problems
Old Dec 17, 2005 | 02:01 PM
DirtyBird222's Avatar
Default Overheating Problems
Ok, I have a 97 Trans Am...has been running very well ever since I bought, put headers on it ect... I took out the fan relay in the fuse box because the fans were never coming on when the temp got around 210! I put a 160 thermostat in there and ghetto rigged a manual fan switch, it worked and that's all I care about, don't care much if it looks ugly under the hood! But around two or three weeks ago the car would start to overheat just randomly so I'd throw the fan switch on and it'd cool down. Then it started overheating after running for not even 5 minutes while driving, and now it is at the point where if I start it up drive down the road sit at a red light for a minute or so it's already over 210! And the fans are not coming on anymore with I flip the switch. There are no leaks in the radiator either. I have not started to look at anything yet, I just want to know what I should look for to start out! Check the fan switch? Drain the coolant, grounds for fans, thermostat, anything else? Thanks in advance for the help.
Old Dec 17, 2005 | 04:28 PM
redlt4's Avatar
The factory setting for the fans to kick on is 226*.
I know that seems high, but the newer small blocks are designed to run that hot. Most guys set the fans to kick on lower with a hypertech programmer or jump the relay to ground like your doing.
Old Dec 18, 2005 | 12:00 PM
Yea but when I had the relay in for the fans it would never turn on! So is there some sort of problem there?
Old Dec 18, 2005 | 12:47 PM
carzman5678's Avatar
My car was overheating, it turned out to be a busted headgasket between cylinders 6 and 8.
Old Dec 18, 2005 | 01:37 PM
Please don't tell me that! J/K I'll be taking everything apart tommorow to check sh*t out, luckily I have my 95 V6 bird to pimp around in until I figure out this damn problem!
Old Dec 18, 2005 | 01:47 PM
dhdenney's Avatar
Sometimes the fans just crap out. I had to replace one once. I guess you'll be ohming those out too.
