Heater Fan help???
Old Dec 18, 2005 | 03:41 PM
LT1Factor's Avatar
Default Heater Fan help???
So my fan for the heat/AC has not been working for sometime and today I replaced the switches praying thats what it was; but still no fan. So my question is, is there a fuse I may have missed or what fuse is it if any? Or what else could it be? Thanks guys
Old Dec 18, 2005 | 05:53 PM
Black1997T/A's Avatar
If the fuse was good I would check that you are getting battery voltage to the switch. If you are getting Batt. voltage at the switch It's either an open connection after the switch or the motor it self is bad. Make sure the wiring to the motor is good and the connectors to the motor are plugged in correctly. Also, make sure that if there is a relay it works properly. A quick and easy way to check it is to swap it out for a known good relay. Hope this helps.
Old Dec 19, 2005 | 09:04 AM
LT1Factor's Avatar
Helps a lot, thanks
