Any way to improve LT1 intake?
Daren
Daren
The car is a 1998 Camaro. It weighs 3200 lb (RW). The motor is a .060 over LT1 with stock LT1 heads (valve job and blueprinted by Jeff Warren). The cam has factory lift and runs 1.94/1.50 valves and uses stamped factory replacement rockers. It runs on 9" x 30" slicks with a TH200 and a 12-bolt with 4.88 gears. I also run Accel DFI.
This car is no way streetable, but it has yet to tap out the factory throttle body, intake, or even the injectors!
Daren
but anyways... back to the point... im not precisely sure on the gain #'s, but it sure doesnt hurt to do it..
My trap speeds are usually 123-125 mph.
The lifters are NHRA "legal" hydraulics. They are pretty much factory lifters converted to solids. The motor is blueprinted to stock specs. which nets a final compression ratio of about 10.4.
Daren
