new times!
Old Dec 20, 2005 | 09:12 PM
94Z71's Avatar
Default new times!
took my car to the track a few weeks ago (clay city, Ky)
with LT's, CAI, 58mm TB, Cut-out, mildly ported stock heads/intake, and a comp #501 cam (on 1.6 rockers though) stock injectors, tune by phil on street tires (bridgestones).
I ran a best of 8.19@87 mph, and a 12.71@108mph on a 1.96 '60 foot.
sound good? the air was COLD COLD COLD something like... 30*.
the car was maxxing out the stock injectors at 5500rpm on a 50* night (the colder the air, the leaner it got) so I figure with a set of 30lb units I should pickup atleast 1mph and a tenth or so?
Old Dec 20, 2005 | 10:16 PM
z28boysteve's Avatar
There is no way your maxing out the injectors at 5,500 with the HP level your at your probably misfiring or floating the valves.. Im running 11.3s at 118 and NOW i think I may be maxing out the injectors at stock fuel pressure.
Old Dec 20, 2005 | 11:24 PM
screamin94Z's Avatar
not too bad times, how big is that cam? i guess if its just "mild" porting of the stock heads you wont pick up too much. depending on the cam size that sounds like a good time, but on cold street tires i bet you hooked like crap.
your injectors definitely arent holding you back though.
Old Dec 20, 2005 | 11:35 PM
buffman's Avatar
I'd be looking at other things besides the injectors.. How old/new is the fuel pump?
Old Dec 24, 2005 | 12:03 AM
94Z71's Avatar
to be totally honest with you all, my car hooked pretty good (track prep was great) I'm not sure how old the pump is in the car, I know for a fact it's not the stock pump because some hill-jack cut an "access panel" over top of the rearend to get to the pump; and no doubt they put on in.
my buddy phil, who did the tuning with CATS hooked his wideband o2 on to the car. everything seemed fine as far as A/F was concerned. watched the duty cycle go from 96% at 5400 to 99-100% at 5500rpm and I only pull the car to 6200rpm. I put '02 LS6 springs with comp beehive retainers and stock ls6 spring shims in, along with +.050" comp locks to get the right install height/ clearance. along with CC pro-mag rockers.
the heads weren't REALLY hogged out a whole lot as far as cc's is concerned, more or less they were "massaged" but no doubt a MAJOR improvement over stock(easily a $500 to $600 port job done for $125 and some spare parts for a full size chevy). I have no clue what the duration is on the cam now, before it was a 212/218, .488"/.495" 112 on 1.5rockers. now the lift spec's at .523"/.528" with 1.6's. with the above valve train setup, I shouldn't (but could) have valve float problems. I'll look in to a pump, didn't pay attention to the fuel pressure during any of the runs, but it could be falling off, but I don't think that's the case here.
