K-Member
Here are some pics of what the BMR K member looks like installed. http://www.exoticperformanceplus.com...tCar.php?car=7 Bob
Ive always liked BMR stuff, and would definitely recommend using there stuff verse some of the competition.
Im also looking for a K-member, Exotic Performance Plus - PM sent.
The discounted display model one is $340.00. There is nothing wrong with it. It has the engine mounts and is set up for the factory steering rack. Shipping is $20.00 for most areas close to the Midwest. Bob
I think they are fine for a daily. Just ensure that you zip tie your brake lines and ABS wiring. That's the one thing I didn't like is that you have to jury rig those components with most aftermarket K-members. On my '94 the ABS wire on the passenger side did bump the header once and got a small burn spot but nothing serious. I had to go back and add another zip tie. My car also developed a "clunk" up front under moderately heavy braking. Have not figured out exactly what is causing this, but it appeared right after the K-member install. Could be the bracket that holds the brake lines. On the passenger side, I don't like how I had to leave mine kinda "floating" just held by zip ties. It bolts to the stock K-member, but on the Pro-Fab there is no provision.
I am already forgetting, but I think the weight savings was ~32 pounds
Jon
pm'd you back.
