LT4 Intakes
First, I'm not buying the "more flow is bad for smallish motors" argument because if that were the case then (A): there wouldn't have ever been any justification for GM to build an LT4 intake in the first place, and (B) LSx guys wouldn't be kicking our asses by running 60cfm MORE and 4 LESS cubes than we are.
Second, it's time to think outside the box and get creative. If GM proved anything with the LS1 engine, it's that how much air you flow is only as important as HOW you flow it. Any LTx intake can be made to flow as much air as an LSx, but it's the difference in power curves and driveability as a result of HOW each intake delivers the air that makes the Lsx come out on top. Is it any wonder that an LT4 intake isn't just a hogged out version of an LT1? Could it be that GM took things other than just flow #'s into consideration when they designed it? When doing a compare/contrast, do you notice a trend that formed between the evolution of the LT1 to the LT4 to the LS1 intake?
Third, and I don't mean to offend anyone by this statement because I'm an LT1 owner myself, but it's this dangerously old fashioned thinking that "big flow #'s only belong on big engines" that is keeping the LT1 guys firmly locked into "underdog" status.
The LT4 intake is not very different nor does it flow more than an LT1 intake it has more material on top of the ports to help in allowing it to be made to match the raised ports on the LT4 heads.
People such as yourself are the problem the LT1 has. With your "LS1s rule" mentality and thought that we have to copy as much as we can from them. That is why the comparatively weak aftermarket for the LT1 even LT1 owners worship the LS1. Furthermore it is people like you and the magazines that keep the LT1 an "underdog". Everyone is so brainwashed of the LT1s inferiority that few show up at the local track though the few that do seem to get attention after they run, mph might not be real high but the ETs are quite good. Before my headers this last summer I actually had someone ask if I was spraying my Caprice, another local stroker LT1 runs deep in the 12s with a driver who sees little track time and was actually built by a basically unemployed mechanic.
First, I'm not buying the "more flow is bad for smallish motors" argument..........
One of the top cylinder head men on the planet told me there is not as much difference in CFM between the two ported factory castings when flow tested with the the factory intake manifolds in place, as you would expect. There is much more to it than CFM.
I didn't start out just wanting to modify an LT1, I was just going to fix a couple of oil leaks in an old car that was leaving spots in the garage floor at my new home. Kinda got out of hand. My wife thinks I should have just put a drip pan under it.
I get that "How much you sprayin' it?" question a lot.
Not a whole lot of same-sized LS1 cars can beat up all of "us".
The fundamental difference between how each of these engines behaves in relation to whatever mods are thrown at them is HOW they deliver airflow. Really, that's all it is. I'm not talking just peak cfm flow capability either, but: runner length, runner shape, plenum volume, port dimensions, port SHAPE, etc. All of these issues are not something that can be easily addressed by a guy hacking up LT1 intakes in his shop and taking a shot in the dark that his hunches are correct and hoping for the best. It's gonna take alot of R&D $$$ for something like this to happen, and the only way I see it coming to light is if an aftermarket company decides to get behind it.
Once again for the LS1 haters: the improvement the LT1 needs is NOT in it's ability to make peak power #'s, but HOW it gets there.
that the Taller deck and a few other minor things make the LS1 a much better platform then the LT1. THAT is where all the power comes from not the intake
Then again the four bolts per cylinder seem to be holding the LSx engines back just a hair at the moment
BTW ALL the LT4 intakes I have "Hacked" up were pretty much Identical internaly to a LT1 intake save for a Dip at the bottom of each port where the gasket meets(that needs filled) and some extra material over the port to seal to the higher port heads. It is easer and cheaper now just to buy a LT1 intake and weld it up to be port for the LT4 heads
THE ONLY Reason it exist is because the LT1 intake would not seal to the heads. GM was releasing the LS1 the next model year and dropped any plans for a better intake on the LT4. Sorry...sad but true
Good luck on your search!
after the heads are converted. MindGame on CZ28 made 565 or so with his 15 degree heads and LTx intake.
I must admit mine are 18* Brodix heads not 15*. then again they use the same parts
BACK to the original idea here. The LT4 intake was NOT really any different then the LT1 and as far as we can measure it was NOT any bigger. I have 'hacked' a few of them up just to be sure
