Some LT1 problems resolved
Old Jan 5, 2006 | 12:51 AM
LT1 Guy's Avatar
Default Some LT1 problems resolved
Came up with a P0400 code for EGR performance and a P0300 code for misfire. Upon further investigation I had a bad EGR valve and EGR solenoid. I replaced both of them but I'm still getting the SES light. I'm thinking it's because there is no back pressure in my exhaust to help the valve work. Oh, well. The misfire is coming from my #5 spark plug wire. Seems to be arching through the damn heat sleeve. I'm so tired of dealing with these stupid spark plug wires. No matter how I route them or what I do to help keep heat off them, one of the little f'ers always melts on me. I need some suggestions to help keep my wires away from my headers.
Old Jan 5, 2006 | 08:28 AM
Chris 96 WS6's Avatar
P0400 happens to lots of cars with headers, and you're right, its because there's not enough back pressure on the EGR valve to get good flow up the little EGR pipe.
Best way to eliminate plug wire problems IMO is to go with over-the-valve-cover setup and do your own custom-length wires.
Old Jan 6, 2006 | 03:47 AM
LT1 Guy's Avatar
I have the over the valve cover setup. How long does it take to change out the wires? If they're going to fry every six months, I might as well save some money and do it myself. I think I'll go with the $120 Taylor set this time instead of the $60 set.
I've also heard of a tape you can wrap your headers with--to help keep the heat in the exhaust? If so, would I have to remove my headers to wrap the tape around them?
Old Jan 10, 2006 | 11:58 PM
coldkillinTA's Avatar
where can you buy the lt1 style custom length ones?? i keep on finding kits but theyre just strait boot instead of strait boot with the smaller connector only for the lt1s
Old Jan 11, 2006 | 12:12 AM
slolt1's Avatar
either over the valve cover or accel extreme heat 9000 work good
Old Jan 11, 2006 | 10:38 PM
my94blackz's Avatar
Taylor otvc is great, but you do have to make them! That sucked. Anyhow i suggest them.
Old Jan 13, 2006 | 10:24 PM
Rare96WS6's Avatar
I used a little heat tape around one or two wires and have not had problems.
