Block off plates
Old Jan 5, 2006 | 12:10 PM
97MysticZ's Avatar
What's a Sticky?
Default Block off plates
I am going to be removing my egr when I do my header install. How many plates do I need? I know I need one on the back of the intake, are there anymore??
Old Jan 5, 2006 | 12:19 PM
Chris 96 WS6's Avatar
There's 2. One to block off where the EGR valve went and one to block off where the tube from the manifold connects to the back of the intake.
Old Jan 5, 2006 | 12:23 PM
blkchevyz's Avatar
actually you only need one, the one for the egr valve. you can get it from the dealer, have them look under an lt4 vette
the air tube that enters the other side is just a passage to the bottom hole on the egr side. the top hole on the egr is the one that actually enters the intake.
Old Jan 5, 2006 | 02:54 PM
MattZ28's Avatar
Actually you don't need any. When there's no vacuum, the EGR valve stays closed, and doesn't allow any air in/out.
Old Jan 5, 2006 | 03:34 PM
blkchevyz's Avatar
dont think i would do that, mine has gotten stuck open.
Old Jan 5, 2006 | 06:37 PM
95zpro's Avatar
not to get off the subject but would an egr valve stuck open cause you to lose vacuum; my vacuum has dropped from a reading of around 17 to 12 on my vacuum boost gauge and before I check for an intake leak I wanted to see if they might be a cause of my problem. I've never changed my egr and don't really know what goes into blocking it off ? Will I have to program my pcm etc.?
