meziere
Old Jan 7, 2006 | 01:19 AM
purple96T/A's Avatar
Default meziere
anybody had any problem with the meziere electric water pumps?mine was working great and just stopped today, no noise,no click,no nothing.
Old Jan 7, 2006 | 11:08 PM
n2ocamaro's Avatar
I guess you have already checked all the wiring? Do you have it hooked up to a relay? If so have you checked the relay? A buddy had this problem on his Meziere a few years ago and it turned out one of the wires came loose internaly. He opened it up, sodered the connection and he hasn't had any problems since.
Old Jan 8, 2006 | 08:31 AM
96capricemgr's Avatar
You might just have a simple problem like that BUT that is also the way electrics fail, suddenly totally stop, not the slow weeping failure of the mechanical.
Old Jan 8, 2006 | 12:32 PM
Shon Herron's Avatar
I have one that needs rebuilt, how much does that usually cost?
Old Jan 11, 2006 | 07:19 AM
toretto's Avatar
how lon have you had yours?
Me and my bud have had ours for almost 2 years or so. nothing but daily driving. i had 20K miles on mine.
double check your wiring, or have someone that knows about wiring check it for you.
Old Jan 11, 2006 | 08:56 AM
roughneck427's Avatar
Meziere here i love its great pump ditched that POS CSR i had damn impeller came off and blew my headgasket.Good thing talked my wife into building my whole motor over it though
Old Jan 11, 2006 | 10:03 AM
Originally Posted by roughneck427
ditched that CSR i had damn impeller came off and blew my headgasket.
This could happen with the Mez too, I ran the CSR on my other car and installed them on several other cars with great results. I would have run the CSR on my car this time but picked up the Mez in some trading, which needs to be rebuilt now so who should I send it to and how much is that?
Old Jan 11, 2006 | 10:16 AM
Try to call meziere talk to a tech,I had called them when the impeller backed off of the CSR the meziere impellers are pressed on and held with a allen screw so i sent the CSR back and got the meziere http://www.meziere.com/
I called them just for **** and gigles just because i have one and wanted to know what to expect if mine failed.The tech said $50 if its a seal and or a bearing thats parts and labor $100 bucks if its an armature thats parts and labor also all them are tested and theres a 2 day turn around
