??recommended valve springs
Old Jan 15, 2006 | 06:29 PM
1uke's Avatar
Default ??recommended valve springs
This is for a Lt4 headed .575 lift Hyd Roller cam,spring seats are uncut as of now.
I'm not sure if cutting the seats is needed if someone can recommend the proper spring. Thanx
Old Jan 15, 2006 | 11:09 PM
white2001s10's Avatar
A comp 918 can handle that lift no problem if you give them the proper install height. That might not be the style of spring you're looking for though.
I think this is the wrong section as well.
