coil wire
Old Jan 16, 2006 | 10:25 PM
coldkillinTA's Avatar
Default coil wire
where in the hell does the coil wire plug into on the opti??
Old Jan 16, 2006 | 10:37 PM
Hambone 7's Avatar
there is a gap between the block and the water pump. if the water pump had a clock face the place you are looking for would be between 1 and 2 o' clock, you should see the coil terminal down in that space.
Old Jan 16, 2006 | 11:10 PM
ooh gotcha thanks man
