Any HPE guys in here???? Rick???
I realize that is a belt drive but what will that whole setup cost and what are the benefits (other than the obvious lower reciprocating weight of losing the chain and vibration of the chain)
Other than the cost of that setup obviously you gotta dump the opti, but did you still use the LT1 waterpump? I can't tell from the pics cuz the motor plate is in the way but the other pics looked like the water inlets were uncovered and useable... What were you using for an ignition system with that timing setup?
I'm contemplating running the LS1 BigStuff 3 setup with a 24x wheel, 8 coils, and a pickup with a standard distributor but I'd like more info on this setup before I make up my mind....
