Valve Spring/ Retainers
Old Jan 19, 2006 | 09:38 PM
LT14Formula's Avatar
Default Valve Spring/ Retainers
Valvespring/retainers Where is a good place to buy em'?
CAM SPECS
xe 218/224 .495/.502 @1.5 110 +4lsa
What kind of springs should I get with that cam and 1.6 RR?
Wheres the best place to order from?
- Z28WannaB
Old Jan 21, 2006 | 01:03 AM
94Z71's Avatar
different folks will say different things but here's what I did, and it would probably be worth it:
bite the big one and go buy yourself a set of comp 26918-16 springs and the corresponding "beehive" retainers, I THINK they are 797-16. about $220 all together, but you'll never worry about valve float, or coil bind.
Old Jan 21, 2006 | 08:53 AM
97Formy's Avatar
787-16 is the part number for the retainers that go with the Beehives.
Old Feb 26, 2006 | 12:07 AM
Camaroguy22's Avatar
795-16 is the part number for steel retainers for the beehives if you want to use 10* locks.
